[GRASS-QA] GRASS QA: hamish | ./grass6/general/g.access/main.c |no clones | 0 monsters | 0 warnings
Wed Nov 8 03:09:44 EST 2006
Hello hamish,
ANALYSIS
general/g.access/main.c functions
main (Begins at: 9 Ends at: 70)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
