[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/set_prior.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 10 05:34:33 EST 2006
Hello brad,
ANALYSIS
lib/gis/set_prior.c functions
init_priority (Begins at: 72 Ends at: 84)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
set_priority (Begins at: 89 Ends at: 108)
Complexity: | 2 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
unset_priority (Begins at: 110 Ends at: 126)
LOC: | 17 | | OK |
metrics are OK
swap_re_uids (Begins at: 128 Ends at: 164)
CalledNBR: | 3 | | OK |
LOC: | 37 | | OK |
metrics are OK
set_uid_to_user (Begins at: 167 Ends at: 187)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
