[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/mapset.c |no clones | 0 monsters | 0 warnings
Fri Nov 10 05:34:32 EST 2006
Hello brad,
ANALYSIS
lib/gis/mapset.c functions
G_mapset (Begins at: 31 Ends at: 65)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G__mapset (Begins at: 68 Ends at: 71)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
