[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.pnmcomp/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 10 07:38:07 EST 2006
Hello glynn,
ANALYSIS
general/g.pnmcomp/main.c functions
erase (Begins at: 30 Ends at: 48)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
read_line (Begins at: 51 Ends at: 61)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
read_header (Begins at: 64 Ends at: 88)
Complexity: | 5 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 25 | | OK |
metrics are OK
read_pnm (Begins at: 91 Ends at: 175)
Complexity: | 20 | * | |
CalledNBR: | 23 | | OK |
LOC: | 85 | | OK |
metrics are OK
overlay (Begins at: 178 Ends at: 217)
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 40 | | OK |
metrics are OK
overlay_alpha (Begins at: 220 Ends at: 252)
LOC: | 33 | | OK |
metrics are OK
write_ppm (Begins at: 255 Ends at: 270)
CalledNBR: | 8 | | OK |
LOC: | 16 | | OK |
metrics are OK
write_pgm (Begins at: 273 Ends at: 288)
LOC: | 16 | | OK |
metrics are OK
main (Begins at: 291 Ends at: 412)
Complexity: | 8 | | OK |
CalledNBR: | 38 | * | |
LOC: | 122 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
