[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/v.outlier/outlier.c |no clones | 1
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Nov 11 12:02:10 EST 2006
Hello markus,
ANALYSIS
vector/lidar/v.outlier/outlier.c functions
P_Outlier (Begins at: 10 Ends at: 180)
Complexity: | 32 | ** | Warning |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 60 | * | |
LOC: | 171 | * | |
1 metric are OUT OF RANGE!
Insert_Outlier (Begins at: 182 Ends at: 195)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
UpDate_Outlier (Begins at: 197 Ends at: 208)
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
Select_Outlier (Begins at: 210 Ends at: 240)
Complexity: | 4 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 31 | | OK |
metrics are OK
P_is_outlier (Begins at: 242 Ends at: 250)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
