[GRASS-QA] GRASS QA: hamish |
	./grass6/raster/r.watershed/ram/close_maps2.c |no clones | 0
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Nov 13 06:29:05 EST 2006
Hello hamish,
ANALYSIS
raster/r.watershed/ram/close_maps2.c functions
close_array_seg (Begins at: 5 Ends at: 131)
Complexity:   |      21 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     127 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
