[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.resamp.stats/main.c
|1 clones ( main.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Nov 14 23:09:02 EST 2006
Hello hamish,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 28 Ends at: 45)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
find_method (Begins at: 47 Ends at: 56)
LOC: | 10 | | OK |
metrics are OK
resamp_unweighted (Begins at: 66 Ends at: 138)
Complexity: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 73 | | OK |
metrics are OK
resamp_weighted (Begins at: 140 Ends at: 229)
CalledNBR: | 20 | | OK |
LOC: | 90 | | OK |
metrics are OK
main (Begins at: 231 Ends at: 370)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 68 | ** | Warning |
LOC: | 140 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
build_method_list
In raster/r.resamp.stats/main.c clones of build_method_list are:
raster/r.series/main.c build_method_list
Threshold GRASS6 key metrics values at 2006-11-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
