[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.group/main.c |no clones | 0 monsters | 0 warnings
Wed Nov 15 03:26:43 EST 2006
Hello hamish,
ANALYSIS
imagery/i.group/main.c functions
main (Begins at: 21 Ends at: 147)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      48 |     * |         |
LOC:          |     127 |     * |         |
metrics are OK
add_or_update_group (Begins at: 150 Ends at: 184)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
add_or_update_subgroup (Begins at: 187 Ends at: 221)
ParamNBR:     |       4 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
remove_group_files (Begins at: 224 Ends at: 266)
Complexity:   |       3 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
remove_subgroup_files (Begins at: 269 Ends at: 312)
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
