[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.kappa/mask.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Nov 15 14:39:57 EST 2006
Hello jachym,
ANALYSIS
raster/r.kappa/mask.c functions
maskinfo (Begins at: 13 Ends at: 44)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 32 | | OK |
metrics are OK
reclass_text (Begins at: 47 Ends at: 68)
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 22 | | OK |
metrics are OK
do_text (Begins at: 71 Ends at: 84)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
append (Begins at: 87 Ends at: 96)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
