[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.kappa/prt_mat.c |1 clones ( prt_mat.c )| 0 monsters | 0 warnings
Wed Nov 15 14:39:57 EST 2006
Hello jachym,
ANALYSIS
raster/r.kappa/prt_mat.c functions
prn_error_mat (Begins at: 12 Ends at: 175)
Complexity:   |      16 |     * |         |
CalledNBR:    |      39 |     * |         |
LOC:          |     164 |     * |         |
metrics are OK
collapse (Begins at: 179 Ends at: 196)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
longcomp (Begins at: 199 Ends at: 205)
Complexity:   |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  longcomp
In raster/r.kappa/prt_mat.c clones of  longcomp are:
	lib/driver/Polygon.c  cmp_int
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
