[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |1 clones ( parser.c )| 1 monsters | 7 warnings
Wed Nov 15 18:00:58 EST 2006
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC:          |      71 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 520)
Complexity:   |      22 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     178 |     * |         |
metrics are OK
G_define_module (Begins at: 523 Ends at: 557)
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_parser (Begins at: 559 Ends at: 816)
Complexity:   |      36 |   *** | MONSTER |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     258 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 819 Ends at: 864)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_usage (Begins at: 866 Ends at: 1039)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     174 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1041 Ends at: 1057)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1059 Ends at: 1263)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     205 |    ** | Warning |
G_usage_html (Begins at: 1265 Ends at: 1496)
Complexity:   |      41 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1498 Ends at: 1583)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
G_gui (Begins at: 1586 Ends at: 1615)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1618 Ends at: 1633)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1635 Ends at: 1664)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1666 Ends at: 1679)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1681 Ends at: 1708)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1713 Ends at: 1722)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1724 Ends at: 1784)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1786 Ends at: 1823)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1825 Ends at: 1867)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 1869 Ends at: 1935)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 1937 Ends at: 1977)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 1979 Ends at: 2006)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2008 Ends at: 2031)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2033 Ends at: 2096)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2098 Ends at: 2136)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2139 Ends at: 2195)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2197 Ends at: 2225)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2227 Ends at: 2235)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2237 Ends at: 2327)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2329 Ends at: 2359)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2361 Ends at: 2406)
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2408 Ends at: 2510)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
