[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/geodesic.c |no clones | 0 monsters | 0 warnings
Thu Nov 16 03:52:08 EST 2006
Hello brad,
ANALYSIS
lib/gis/geodesic.c functions
G_begin_geodesic_equation (Begins at: 39 Ends at: 71)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G_geodesic_lat_from_lon (Begins at: 75 Ends at: 81)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
adjust_lon (Begins at: 83 Ends at: 91)
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
adjust_lat (Begins at: 93 Ends at: 99)
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-16 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
