[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.legend/main.c |no clones | 3 monsters | 0 warnings
Fri Nov 17 03:58:36 EST 2006
Hello hamish,
ANALYSIS
display/d.legend/main.c functions
main (Begins at: 38 Ends at: 896)
Complexity:   |     126 |   *** | MONSTER |
CalledNBR:    |     233 |   *** | MONSTER |
LOC:          |     859 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
