[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |1 clones (
parser.c parser.c )| 1 monsters | 7 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 17 03:58:36 EST 2006
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC: | 71 | | OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 524)
Complexity: | 22 | * | |
CalledNBR: | 25 | | OK |
LOC: | 182 | * | |
metrics are OK
G_define_module (Begins at: 527 Ends at: 561)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 563 Ends at: 820)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 71 | ** | Warning |
LOC: | 258 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 823 Ends at: 868)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 870 Ends at: 1043)
Complexity: | 31 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 174 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1045 Ends at: 1061)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1063 Ends at: 1267)
Complexity: | 26 | ** | Warning |
CalledNBR: | 65 | ** | Warning |
LOC: | 205 | ** | Warning |
G_usage_html (Begins at: 1269 Ends at: 1500)
Complexity: | 41 | *** | MONSTER |
CalledNBR: | 80 | ** | Warning |
LOC: | 232 | ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1502 Ends at: 1587)
Complexity: | 10 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 86 | | OK |
metrics are OK
G_gui (Begins at: 1590 Ends at: 1619)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_tcltk (Begins at: 1622 Ends at: 1637)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1639 Ends at: 1668)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1670 Ends at: 1683)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1685 Ends at: 1712)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1717 Ends at: 1726)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1728 Ends at: 1788)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1790 Ends at: 1827)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1829 Ends at: 1871)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1873 Ends at: 1939)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1941 Ends at: 1981)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1983 Ends at: 2010)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2012 Ends at: 2035)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2037 Ends at: 2100)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2102 Ends at: 2140)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2143 Ends at: 2199)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2201 Ends at: 2229)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2231 Ends at: 2239)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2241 Ends at: 2331)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2333 Ends at: 2363)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2365 Ends at: 2410)
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2412 Ends at: 2514)
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-11-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
