[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.surf.fractal/spec_syn.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 17 15:56:42 EST 2006
Hello markus,
ANALYSIS
raster/r.surf.fractal/spec_syn.c functions
specsyn (Begins at: 19 Ends at: 160)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 142 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
