[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/progrm_nme.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Nov 18 10:32:26 EST 2006
Hello paul,
ANALYSIS
lib/gis/progrm_nme.c functions
G_program_name (Begins at: 32 Ends at: 35)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_set_program_name (Begins at: 37 Ends at: 57)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
