[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.median/read_stats.c
|1 clones ( read_stats.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 19 06:17:31 EST 2006
Hello jachym,
ANALYSIS
raster/r.median/read_stats.c functions
read_stats (Begins at: 6 Ends at: 16)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
read_stats
In raster/r.median/read_stats.c clones of read_stats are:
raster/r.mode/read_stats.c read_stats
Threshold GRASS6 key metrics values at 2006-11-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
