[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/get_stp.c |no clones | 1 monsters | 0 warnings
Sun Oct 1 17:25:55 EDT 2006
Hello glynn,
ANALYSIS
general/g.setproj/get_stp.c functions
get_stp_proj (Begins at: 7 Ends at: 41)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
get_stp_code (Begins at: 43 Ends at: 73)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
get_stp_num (Begins at: 79 Ends at: 136)
Complexity:   |       9 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
ask_fips (Begins at: 141 Ends at: 321)
Complexity:   |      31 |    ** | Warning |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      88 |   *** | MONSTER |
LOC:          |     181 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
