[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.distance/edges.c |no clones | 0 monsters | 0 warnings
Mon Oct 2 14:14:50 EDT 2006
Hello jachym,
ANALYSIS
raster/r.distance/edges.c functions
print_edge_info (Begins at: 21 Ends at: 28)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
find_edge_cells (Begins at: 30 Ends at: 93)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
add_edge_cell (Begins at: 95 Ends at: 138)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
init_edge_list (Begins at: 140 Ends at: 146)
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
cmp (Begins at: 148 Ends at: 152)
LOC:          |       5 |       |      OK |
metrics are OK
sort_edge_list (Begins at: 154 Ends at: 158)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      81 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
