[GRASS-QA] GRASS QA: glynn | ./grass6/lib/stats/c_count.c |1 clones ( c_ave.c c_count.c )| 0 monsters | 0 warnings
Mon Oct 2 19:00:23 EDT 2006
Hello glynn,
ANALYSIS
lib/stats/c_count.c functions
c_count (Begins at: 3 Ends at: 15)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
w_count (Begins at: 17 Ends at: 29)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  c_count
In lib/stats/c_count.c clones of  c_count are:
	raster/r.series/c_count.c  c_count
Threshold GRASS6 key metrics values at 2006-10-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      81 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
