[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrstring.c
|1 clones ( xdrchar.c xdrcolumn.c xdrdatetime.c xdrdouble.c
xdrint.c xdrshort.c xdrstring.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:39 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrstring.c functions
db__send_string_array (Begins at: 7 Ends at: 17)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
db__recv_string_array (Begins at: 21 Ends at: 55)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 35 | | OK |
metrics are OK
db__send_string (Begins at: 58 Ends at: 92)
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 35 | | OK |
metrics are OK
db__recv_string (Begins at: 95 Ends at: 122)
Complexity: | 4 | | OK |
LOC: | 28 | | OK |
metrics are OK
db__send_Cstring (Begins at: 125 Ends at: 133)
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In lib/db/dbmi_base/xdrstring.c clones of db__send_string_array are:
lib/imagery/sig2cats.c I_signature_to_cats
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
