[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.setup/main.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:42 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/main.c functions
main (Begins at: 44 Ends at: 129)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
get_pwd (Begins at: 135 Ends at: 145)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
