[GRASS-QA] GRASS QA: hamish |
./grass6/raster/r.le/r.le.setup/sample.c |no clones | 10
monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:42 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/sample.c functions
sample (Begins at: 51 Ends at: 115)
Complexity: | 5 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 16 | | OK |
LOC: | 65 | | OK |
at least 1 values are close to an outlier please consider revising code
man_unit (Begins at: 121 Ends at: 652)
Complexity: | 57 | *** | MONSTER |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 157 | *** | MONSTER |
LOC: | 532 | *** | MONSTER |
4 metric are OUT OF RANGE!
draw_grid (Begins at: 657 Ends at: 718)
Complexity: | 3 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 8 | | OK |
LOC: | 62 | | OK |
1 metric are OUT OF RANGE!
calc_unit_loc (Begins at: 723 Ends at: 959)
Complexity: | 28 | ** | Warning |
ParamNBR: | 22 | *** | MONSTER |
CalledNBR: | 44 | * | |
LOC: | 237 | ** | Warning |
get_rd (Begins at: 964 Ends at: 976)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
f (Begins at: 981 Ends at: 986)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
overlap (Begins at: 991 Ends at: 997)
ParamNBR: | 6 | * | |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
calc_num (Begins at: 1002 Ends at: 1028)
Complexity: | 4 | | OK |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
graph_unit (Begins at: 1036 Ends at: 1431)
Complexity: | 35 | ** | Warning |
CalledNBR: | 117 | *** | MONSTER |
LOC: | 396 | *** | MONSTER |
3 metric are OUT OF RANGE!
draw_box (Begins at: 1436 Ends at: 1465)
ParamNBR: | 5 | * | |
CalledNBR: | 11 | | OK |
LOC: | 30 | | OK |
metrics are OK
draw_circle (Begins at: 1470 Ends at: 1510)
CalledNBR: | 7 | | OK |
LOC: | 41 | | OK |
metrics are OK
numtrap (Begins at: 1515 Ends at: 1583)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 69 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
