[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.le/r.le.setup/ask_group.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:41 EDT 2006
Hello glynn,
ANALYSIS
raster/r.le/r.le.setup/ask_group.c functions
ask_group (Begins at: 40 Ends at: 89)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
get_group_drv (Begins at: 91 Ends at: 160)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
ask_limits (Begins at: 162 Ends at: 184)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
get_index (Begins at: 186 Ends at: 217)
Complexity:   |       3 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
ask_reclass (Begins at: 219 Ends at: 263)
CalledNBR:    |      17 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
get_1recl (Begins at: 271 Ends at: 337)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
ask_fromto (Begins at: 339 Ends at: 369)
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
fopen0 (Begins at: 371 Ends at: 382)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
