[GRASS-QA] GRASS QA: hamish |
	./grass6/raster/r.le/r.le.patch/main.c |no clones | 1
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Oct 11 05:10:42 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.patch/main.c functions
main (Begins at: 36 Ends at: 156)
Complexity:   |      60 |   *** | MONSTER |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     121 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
