[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.digit/get_circle.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:40 EDT 2006
Hello brad,
ANALYSIS
raster/r.digit/get_circle.c functions
get_circle (Begins at: 29 Ends at: 126)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
draw_and_record (Begins at: 129 Ends at: 143)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
