[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrprocedure.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:39 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrprocedure.c functions
db__start_procedure_call (Begins at: 7 Ends at: 27)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
db__recv_procnum (Begins at: 36 Ends at: 49)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
db__send_procedure_ok (Begins at: 52 Ends at: 55)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
db__send_procedure_not_implemented (Begins at: 58 Ends at: 61)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
