[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrindex.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:39 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrindex.c functions
db__send_index (Begins at: 6 Ends at: 22)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
db__send_index_array (Begins at: 25 Ends at: 35)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
db__recv_index (Begins at: 38 Ends at: 58)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
db__recv_index_array (Begins at: 61 Ends at: 77)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
