[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.digit/setup_graph.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:10:40 EDT 2006
Hello brad,
ANALYSIS
raster/r.digit/setup_graph.c functions
move (Begins at: 22 Ends at: 25)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
cont (Begins at: 27 Ends at: 30)
LOC: | 4 | | OK |
metrics are OK
setup_graphics (Begins at: 32 Ends at: 40)
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
