[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 11 05:38:41 EDT 2006
Hello hamish,
ANALYSIS
display/d.vect/main.c functions
icon_files (Begins at: 32 Ends at: 78)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 47 | | OK |
metrics are OK
test_bg_color (Begins at: 81 Ends at: 96)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
main (Begins at: 99 Ends at: 644)
Complexity: | 75 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 182 | *** | MONSTER |
LOC: | 546 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
