[GRASS-QA] GRASS QA: hamish | ./grass6/raster3d/r3.in.ascii/main.c
	|1 clones ( parser.c main.c main.c main.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Oct 11 05:38:41 EDT 2006
Hello hamish,
ANALYSIS
raster3d/r3.in.ascii/main.c functions
fatalError (Begins at: 50 Ends at: 59)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
setParams (Begins at: 70 Ends at: 91)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
getParams (Begins at: 96 Ends at: 107)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
readHeaderString (Begins at: 112 Ends at: 122)
ParamNBR:     |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
openAscii (Begins at: 127 Ends at: 155)
CalledNBR:    |      15 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
asciiToG3d (Begins at: 162 Ends at: 208)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
main (Begins at: 212 Ends at: 272)
CalledNBR:    |      23 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  fatalError
In raster3d/r3.in.ascii/main.c clones of  fatalError are:
	lib/g3d/g3dclose.c  G3d_closeOld
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
