[GRASS-QA] GRASS QA: hamish | ./grass6/lib/g3d/g3dparam.c |no clones | 1 monsters | 0 warnings
Wed Oct 11 05:38:41 EDT 2006
Hello hamish,
ANALYSIS
lib/g3d/g3dparam.c functions
G3d_setStandard3dInputParams (Begins at: 41 Ends at: 84)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
G3d_getStandard3dParams (Begins at: 88 Ends at: 155)
Complexity:   |      12 |       |      OK |
ParamNBR:     |      12 |   *** | MONSTER |
CalledNBR:    |      20 |       |      OK |
LOC:          |      68 |       |      OK |
1 metric are OUT OF RANGE!
G3d_setWindowParams (Begins at: 162 Ends at: 172)
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G3d_getWindowParams (Begins at: 176 Ends at: 184)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
