[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.xyz/main.c |no clones | 3 monsters | 0 warnings
Thu Oct 12 03:39:58 EDT 2006
Hello hamish,
ANALYSIS
raster/r.in.xyz/main.c functions
main (Begins at: 24 Ends at: 610)
Complexity:   |      86 |   *** | MONSTER |
CalledNBR:    |     202 |   *** | MONSTER |
LOC:          |     587 |   *** | MONSTER |
3 metric are OUT OF RANGE!
scan_bounds (Begins at: 614 Ends at: 706)
Complexity:   |      17 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      24 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
