[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.buffer/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 14 13:00:20 EDT 2006
Hello jachym,
ANALYSIS
raster/r.buffer/main.c functions
main (Begins at: 31 Ends at: 187)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 50 | * | |
LOC: | 157 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
