[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.contour/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 14 13:30:09 EDT 2006
Hello jachym,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 53 Ends at: 220)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 77 | ** | Warning |
LOC: | 168 | * | |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 223 Ends at: 239)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 17 | | OK |
metrics are OK
getlevels (Begins at: 243 Ends at: 341)
Complexity: | 10 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 26 | | OK |
LOC: | 99 | | OK |
metrics are OK
displaceMatrix (Begins at: 349 Ends at: 373)
Complexity: | 2 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 25 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
