[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.cross/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 14 14:24:52 EDT 2006
Hello jachym,
ANALYSIS
raster/r.cross/main.c functions
main (Begins at: 30 Ends at: 201)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 73 | ** | Warning |
LOC: | 172 | * | |
at least 1 values are close to an outlier please consider revising code
cmp (Begins at: 203 Ends at: 214)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
