[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.colors/main.c |1
clones ( main.c )| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 17 07:50:42 EDT 2006
Hello glynn,
ANALYSIS
raster/r.colors/main.c functions
rules_files (Begins at: 34 Ends at: 77)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 44 | | OK |
metrics are OK
cmp_names (Begins at: 79 Ends at: 85)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
list_rules_files (Begins at: 87 Ends at: 131)
Complexity: | 5 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 45 | | OK |
metrics are OK
main (Begins at: 133 Ends at: 357)
Complexity: | 40 | *** | MONSTER |
CalledNBR: | 106 | *** | MONSTER |
LOC: | 225 | ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
cmp_names
In raster/r.colors/main.c clones of cmp_names are:
lib/gis/datum.c compare_table_names
Threshold GRASS6 key metrics values at 2006-10-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
