[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/range.c |1 clones ( range.c )| 0 monsters | 0 warnings
Tue Oct 17 13:39:33 EDT 2006
Hello markus,
ANALYSIS
lib/gis/range.c functions
G__remove_fp_range (Begins at: 93 Ends at: 111)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_construct_default_range (Begins at: 113 Ends at: 138)
LOC:          |      26 |       |      OK |
metrics are OK
G_read_fp_range (Begins at: 140 Ends at: 231)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
G_read_range (Begins at: 233 Ends at: 341)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |     109 |       |      OK |
metrics are OK
G_write_range (Begins at: 343 Ends at: 390)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
G_write_fp_range (Begins at: 392 Ends at: 444)
Complexity:   |       5 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_update_range (Begins at: 446 Ends at: 464)
CalledNBR:    |       1 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_update_fp_range (Begins at: 468 Ends at: 501)
LOC:          |      34 |       |      OK |
metrics are OK
G_row_update_range (Begins at: 503 Ends at: 508)
LOC:          |       6 |       |      OK |
metrics are OK
G__row_update_range (Begins at: 512 Ends at: 538)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G_row_update_fp_range (Begins at: 542 Ends at: 596)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
G_init_range (Begins at: 598 Ends at: 625)
LOC:          |      28 |       |      OK |
metrics are OK
G_get_range_min_max (Begins at: 627 Ends at: 663)
CalledNBR:    |       6 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_init_fp_range (Begins at: 665 Ends at: 688)
LOC:          |      24 |       |      OK |
metrics are OK
G_get_fp_range_min_max (Begins at: 690 Ends at: 713)
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G__remove_fp_range
In lib/gis/range.c clones of  G__remove_fp_range are:
	lib/gis/timestamp.c  G_remove_vector_timestamp
	lib/gis/histogram.c  G_remove_histogram
Threshold GRASS6 key metrics values at 2006-10-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
