[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/list.c |no clones | 0 monsters | 0 warnings
Wed Oct 18 12:51:43 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/list.c functions
G_set_list_hit_return (Begins at: 60 Ends at: 64)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_list_element (Begins at: 66 Ends at: 145)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
sigpipe_catch (Begins at: 147 Ends at: 151)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
list_element (Begins at: 153 Ends at: 271)
Complexity:   |      20 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |     119 |     * |         |
metrics are OK
pstrcmp (Begins at: 273 Ends at: 286)
LOC:          |      14 |       |      OK |
metrics are OK
G_list (Begins at: 288 Ends at: 355)
Complexity:   |      12 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
G_free_list (Begins at: 357 Ends at: 369)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
