[GRASS-QA] GRASS QA: markus | ./grass6/lib/init/set_data.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 18 17:26:44 EDT 2006
Hello markus,
ANALYSIS
lib/init/set_data.c functions
main (Begins at: 53 Ends at: 272)
Complexity: | 27 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 88 | *** | MONSTER |
LOC: | 220 | ** | Warning |
1 metric are OUT OF RANGE!
list_locations (Begins at: 275 Ends at: 284)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 10 | | OK |
metrics are OK
list_mapsets (Begins at: 287 Ends at: 330)
Complexity: | 8 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 44 | | OK |
metrics are OK
first_word (Begins at: 333 Ends at: 342)
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
hit_return (Begins at: 345 Ends at: 353)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
