[GRASS-QA] GRASS QA: hamish |
	./grass6/raster/r.le/r.le.setup/main.c |no clones | 0
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Oct 19 03:01:39 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/main.c functions
main (Begins at: 42 Ends at: 126)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
get_pwd (Begins at: 132 Ends at: 142)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
