[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.pixel/input.c |no clones | 3 monsters | 0 warnings
Thu Oct 19 03:01:39 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.pixel/input.c functions
user_input (Begins at: 28 Ends at: 341)
Complexity:   |      46 |   *** | MONSTER |
CalledNBR:    |     103 |   *** | MONSTER |
LOC:          |     314 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
