[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.in.ascii/main.c |no
	clones | 1 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Oct 22 07:34:40 EDT 2006
Hello jachym,
ANALYSIS
raster/r.in.ascii/main.c functions
main (Begins at: 18 Ends at: 253)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      98 |   *** | MONSTER |
LOC:          |     236 |    ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 256 Ends at: 284)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
