[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.in.poly/poly2rast.c |no clones | 0 monsters | 0 warnings
Sun Oct 22 12:50:08 EDT 2006
Hello jachym,
ANALYSIS
raster/r.in.poly/poly2rast.c functions
poly_to_rast (Begins at: 7 Ends at: 81)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
