[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/percent.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 23 03:21:49 EDT 2006
Hello brad,
ANALYSIS
lib/gis/percent.c functions
G_percent (Begins at: 55 Ends at: 89)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_percent2 (Begins at: 91 Ends at: 137)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 47 | | OK |
metrics are OK
G_percent_reset (Begins at: 145 Ends at: 151)
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
