[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/get_ellipse.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 23 05:36:23 EDT 2006
Hello markus,
ANALYSIS
lib/gis/get_ellipse.c functions
G_get_ellipsoid_parameters (Begins at: 63 Ends at: 178)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 116 | * | |
metrics are OK
G_get_ellipsoid_by_name (Begins at: 181 Ends at: 254)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 74 | | OK |
metrics are OK
G_ellipsoid_name (Begins at: 257 Ends at: 287)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 31 | | OK |
metrics are OK
G_get_spheroid_by_name (Begins at: 290 Ends at: 320)
ParamNBR: | 4 | | OK |
LOC: | 31 | | OK |
metrics are OK
G_ellipsoid_description (Begins at: 323 Ends at: 327)
LOC: | 5 | | OK |
metrics are OK
get_a_e2_f (Begins at: 330 Ends at: 369)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 40 | | OK |
metrics are OK
ellipsoid_table_file (Begins at: 371 Ends at: 375)
LOC: | 5 | | OK |
metrics are OK
compare_table_names (Begins at: 378 Ends at: 382)
LOC: | 5 | | OK |
metrics are OK
read_ellipsoid_table (Begins at: 385 Ends at: 460)
CalledNBR: | 25 | | OK |
LOC: | 76 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
