[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/select.c |no clones | 0 monsters | 0 warnings
Mon Oct 23 12:22:04 EDT 2006
Hello markus,
ANALYSIS
lib/db/dbmi_client/select.c functions
cmp (Begins at: 6 Ends at: 14)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
cmpcat (Begins at: 16 Ends at: 24)
LOC:          |       9 |       |      OK |
metrics are OK
cmpcatkey (Begins at: 26 Ends at: 46)
LOC:          |      21 |       |      OK |
metrics are OK
db_select_int (Begins at: 48 Ends at: 136)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
db_select_value (Begins at: 138 Ends at: 190)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
db_select_CatValArray (Begins at: 192 Ends at: 303)
Complexity:   |      16 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
db_CatValArray_sort (Begins at: 307 Ends at: 310)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
db_CatValArray_get_value (Begins at: 316 Ends at: 326)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
db_CatValArray_get_value_int (Begins at: 332 Ends at: 342)
LOC:          |      11 |       |      OK |
metrics are OK
db_CatValArray_get_value_double (Begins at: 348 Ends at: 360)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-23 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
