[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/seg/close_maps2.c |no clones | 0 monsters | 0 warnings
Thu Oct 26 03:39:37 EDT 2006
Hello hamish,
ANALYSIS
raster/r.watershed/seg/close_maps2.c functions
close_array_seg (Begins at: 5 Ends at: 97)
Complexity:   |      18 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
