[GRASS-QA] GRASS QA: hamish |
./grass6/raster/r.watershed/seg/sg_factor.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Oct 26 03:39:37 EDT 2006
Hello hamish,
ANALYSIS
raster/r.watershed/seg/sg_factor.c functions
sg_factor (Begins at: 7 Ends at: 42)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 36 | | OK |
metrics are OK
len_slp_equ (Begins at: 45 Ends at: 64)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
