[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.random/count.c |2 clones ( main.c count.c )| 0 monsters | 0 warnings
Sat Oct 28 17:01:25 EDT 2006
Hello glynn,
ANALYSIS
raster/r.random/count.c functions
get_stats (Begins at: 15 Ends at: 88)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
set_min (Begins at: 91 Ends at: 119)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
set_max (Begins at: 122 Ends at: 150)
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  set_max  set_min
In raster/r.random/count.c clones of  set_max are:
	raster/r.random/count.c  set_min
In raster/r.random/count.c clones of  set_min are:
	raster/r.random/count.c  set_max
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
